Belt Tensioner Bolt Length - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2010, 10:10 AM   #1 (permalink)
View sawyer65's Photo Gallery
I am trying to find the diameter and length of the pivot bolt for the serptine belt tensioner.
I think there is a piece of old bolt broke off in the hole.
I had the engine rebuilt over a year ago and it looks the guy cobbled up something to work,the "bolt" that was in it,is more like a stud with a nut welded on the end.Looking at the hole in the block,it looks like he ran a 9/16 drill in about 1/2 an inch,my guess would be to either get enough clearance to get it started or clean out some bad threads in the end.
If I can find the length of the original bolt,I can determine if there is indeed a piece of bolt broke off in there and aprox how long it is.
I do not have a haynes,I do need to pick one up.
I have searched for a couple of hours here,can find lots of threads with a reference to the bolt but none containing the actual diameter and length
sawyer65 is offline   Reply With Quote
Old 07-25-2010, 12:08 PM   #2 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
Its a 10mm dia. bolt and measures 106 mm from under the head to the end.
With the timing cover on the hole depth is 60 mm. Thread is 1.5
sam333 is offline   Reply With Quote
Old 11-14-2010, 05:16 PM   #3 (permalink)
View dieseltrooper's Photo Gallery
I just found that my pivot bolt has sheared/twisted off inside the block. What's the scoop on fixing it? Hoping you don't say "First, pull the engine..."
dieseltrooper is offline   Reply With Quote
Old 11-14-2010, 05:39 PM   #4 (permalink)
Look here: http://www.corolland.com/forums/inde...cover-removal/
Old 11-16-2010, 06:16 AM   #5 (permalink)
Tried to get a angle-drill in there but, no joy. Looks like it's the hard way for this one.
