Catalytic Converter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2010, 04:44 PM   #1 (permalink)
C0R011A's Avatar
View C0R011A's Photo Gallery
Catalytic Converter
Hey guys, I am pretty sure my catalytic converter is shot and i need a new one. i have a constant rattle under my car and it is the worst when the car is idle and gradual lessens as i increase speed. Anyway, i was wondering how much it would cost to replace on average. I just want some ballpark numbers before i go to the shop.
Thanks
C0R011A is offline   Reply With Quote
Old 07-26-2010, 09:06 PM   #2 (permalink)
View GreenYoda's Photo Gallery
If your cat was shot then you would probably be getting a Check Engine Light coming on and staying on. If thats not the case then it could be a heatsheild coming loose somewhere, might just wanna jack the car up and take a look before you waste money on something you don't need replacing right now.
GreenYoda is offline   Reply With Quote
Old 07-27-2010, 05:17 AM   #3 (permalink)
View dgoodhue's Photo Gallery
Jack up the car and check your heat shields. Over time, the bolts on mine have rusted and fall off causing rattles. I ended up removing all of them.
Dave
02 Highlander
dgoodhue is offline   Reply With Quote
Old 07-27-2010, 04:39 PM   #4 (permalink)
C0R011A's Avatar
The check engine light has been on in my car for as long as Ive had the car (it was a pass me down from my dad then brother). It doesn't seem to go off even when I fix everything causing it to illuminate. And is the heat shield a straightforward fix?
