What is the "recommended" tire PSI? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2010, 12:41 AM   #1 (permalink)
View chungenhung's Photo Gallery
Just bought a used 98 Corolla.
Was wondering, what should the PSI level be?
The tire its got on only shows "Do not exceed 45 PSI".
The User Manual does not say anything about PSI levels.
I know every car is a little bit different, so what should be the correct value?
chungenhung is offline   Reply With Quote
Old 07-30-2010, 01:05 AM   #2 (permalink)
Raging Raven
View TenZen's Photo Gallery
30-35 PSI usually.
2005 Dodge Neon SRT-4
Originally Posted by FinalGear View Post
gosh...those honda guys....as soon as they put the intake in their Civics...it goes faster than any Mustang, Evo, and Sti....
TenZen is offline   Reply With Quote
Old 07-30-2010, 01:11 AM   #3 (permalink)
View aznstylez's Photo Gallery
It should say by your door. 28-32 I think for a 4 cylinder.
aznstylez is offline   Reply With Quote
Old 07-30-2010, 01:15 AM   #4 (permalink)
I checked the label on the door, it does not say anything at all!
Old 07-30-2010, 02:00 AM   #5 (permalink)
View mr1114's Photo Gallery
I run no less than 36 PSI cold in my cars, for slightly better MPG, and because anything less I consider low. Some people like lower pressures or going by what the door tag says, for a smoother ride, and because they think the tire will "explode" if ran at slightly higher PSI than what the manufacturer calls for.
2006 Corolla S - sold
2003 Solara SLE - sold
2000 Corolla LE - sold
mr1114 is offline   Reply With Quote
Old 07-30-2010, 08:10 AM   #6 (permalink)
On my 4th Toyota!
View noodlesoup's Photo Gallery
Probably ~32 for best tire wear and ~37 for best fuel economy. I keep mine at 38 cold psi
noodlesoup is offline   Reply With Quote
Old 07-30-2010, 09:07 AM   #7 (permalink)
View Kyle Hamelin's Photo Gallery
it should say it right in your glove box thing. there should be a big sticker on it.
Kyle Hamelin is offline   Reply With Quote
Old 07-30-2010, 10:41 AM   #8 (permalink)
On my 4th Toyota!
Also, as a general rule if you like higher psi's stay at least 6 psi below the maximum amount listed on the side of the tire.
This is based on my experience with stock rims/ tires
