things im curious of
Okay...so when doing the TB coolant bypass, is it legal to pass smog leaving those two hose wide open unplug with hoses???I mean for the 1zz corolla stock Tb...the tb coolant hose are facing back so u wont see it but when swapping the celica TB...one coolant faces the front and faces behind, so the point is when u go smog will they require it to be plug back in????
Another one is....after installing a celica IM and TB...would it even help more to install a celica TB spacer???Cause it work only on certain cars w/ the spacer so any ideas?
thanks
