air nob after coolant drain and fill. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2010, 03:35 PM   #1 (permalink)
View gcorolla99's Photo Gallery
This is for a 1999 corolla.
I'm going to just drain the coolant every two years and plan on refilling it w/o flushing. Is there any air release nob I have to release afterwards?
Thanks.
gcorolla99 is offline   Reply With Quote
Old 08-12-2010, 04:25 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Drain and refill will be OK, but not hard to do a decent flush.
Flush the system with distilled water - pretty easy to do. Just drain the coolant, refill with distilled water, run it a bit. Let it cool down, repeat until the water runs clear. Refill half the total capacity with straight coolant, top off the rest with distilled - perfect 50/50 mix. Stick with Toyota Red coolant (straight coolant), the pink stuff is premixed.
After you are done, flush the coolant reservoir about 1/2 way with a 50/50 mix. Drive normally, as the system "burbs" the air out, it will draw in additional coolant automatically. Just top off the coolant reservoir tank as needed and you'll be good to go.
The Following User Says Thank You to fishexpo101 For This Useful Post:
2004 (08-26-2010)
Old 08-12-2010, 06:43 PM   #3 (permalink)
Hi Fish, why stick with the Toyota pink? 1999 corolla.
