coolant is rusty brown?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2010, 02:22 PM   #1 (permalink)
mital917's Avatar
View mital917's Photo Gallery
i got a 2001 corolla and for the past few days the car has been heating up and i filled up coolant but a few days later it turned a rusty brown color do i need a full system flush or does my HG needs to be replaced
the car is leaking oil but it if from the vvti solenoid
i can use all the help so let me know what i should do
mital917 is offline   Reply With Quote
Old 08-20-2010, 08:07 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
White smoke? drain some coolant and try to shake it. Any bubbles? Others may have a better idea of what oil in coolant looks like. That's what you should be looking for.
Once you made certain that engine oil is not leaking into the cooling system and vice versa, I'd flush the system clean with tons of distilled water and fill it with new Toyota Red.
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 08-20-2010, 09:39 PM   #3 (permalink)
View Corollaczy's Photo Gallery
I would describe oil in coolant like coffee with some creamer in it. if you pull the valve cover its going to be painfully obvious that you have a problem and the oil is just going to look wrong, in my dads civic it looked all smeared different colors and what not. And that means blown gasket
Corollaczy is offline   Reply With Quote
