Spring time - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2010, 11:37 PM   #1 (permalink)
View tank1080's Photo Gallery
Spring time
Hey like someone elses thread also said time for new springs in the rear. I'm thinking about lowering springs but the only thing is, everytime i hit a bump now my exhaust hits the ground. Are lowering springs stiff? or would they just be like my worn out springs?
tank1080 is offline   Reply With Quote
Old 08-24-2010, 04:15 AM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Yes, lowering springs are a lot stiffer than standard springs. I can barely push the front and rear down on my 7th Gen due to the stiffness of the aftermarket springs. You can still bottom-out when going over large bumps, but it takes a lot more force than the standard springs. If you're still concerned, then you can upgrade your shock absorbers too.
Old 08-24-2010, 01:23 PM   #3 (permalink)
on full afterburner
Gameroom cash: $1345597
If you're bottoming out then your struts need replacing as well.
Old 09-01-2010, 10:36 AM   #4 (permalink)
not true! i just replace the struts but thanks for info on the lowering spring
Old 09-01-2010, 11:06 AM   #5 (permalink)
on full afterburner
You should have mentioned that in your original post then.
My reply was based on an assumption that you struts were worn.
