Auto 4 speed transmission slipping, what options are there? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2010, 05:18 PM   #1 (permalink)
View Super Blue's Photo Gallery
Hi guys,
My 98 4speed auto seems to be slipping quite badly as of late. The car has about 190k kms on it now. The previous owner had changed the fluid at about 120k. I changed the fluid when it initially started slipping and also added 1/2 a bottle of Lucus Tranny fix. It helped a little but not too much.
Also in the beginning the transmission only slipped if I accelerated heavily from a dead stop, but now it seems to slip anytime when the engine load is abruptly increased, in other words any time I foot down harder than light acceleration. I've noticed it definitely slips more when the AC is on.
Is the transmission toast, or is it salvageable? Would changing the tranny fluid and filter make any difference?
Super Blue is offline   Reply With Quote
Old 09-08-2010, 09:01 AM   #2 (permalink)
View dorman68's Photo Gallery
When you changed the fluid, did you pull the pan down and clean out the filter screen? Possibly the screen could be partially clogged and causing slippage.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 09-08-2010, 01:05 PM   #3 (permalink)
The last time was a drain and fill only. I didn't take the pan off.
Would a tranny flush help clear up the screen, or should I just take the pan off the change the filter screen. I am really hoping that is all the issue is.
Old 09-11-2010, 10:56 AM   #4 (permalink)
View rideat45's Photo Gallery
sounds like the seals may be going, form what you are describing, that may not require a complete overhaul but the case still needs to be opened, does it happen when the transmission is cold and then as the unit heats up does it slip less?
rideat45 is offline   Reply With Quote
Old 09-14-2010, 09:29 AM   #5 (permalink)
I don't feel a flush would help you in your situation. If it were my car I would be really curious to see what the filter/screen looks like.
Old 09-15-2010, 08:14 AM   #6 (permalink)
The tranny seems not to be slipping any more, I think the Lucus needed more time to do it's magic. However, now I have a new problem. I did a engine shampoo over the weekend, and now the car seems to be running terribly. What is the usual issue that comes up after rinsing down an engine? I did take the precaution to cover up electrical connections.
The issue is, even with the car in park as soon as I give it some gas, the engine starts to shrug.
Had an similar issue with my TJ back in the day, turned out to be one of the sensors around the throttle body, could it be a similar problem in the corolla?
Checked the code, came up as P0304, misfire cylinder 4.
Old 09-17-2010, 02:38 PM   #7 (permalink)
View Whiskey's Photo Gallery
You probably got water down the spark plug holes - or your wires are shot, got water in the little micro cracks and caused the misfire.
I ended up replacing my wires when i had the same issue and it was fine.
Whiskey
Whiskey is offline   Reply With Quote
The Following User Says Thank You to Whiskey For This Useful Post:
Super Blue (09-17-2010)
Old 09-17-2010, 05:37 PM   #8 (permalink)
Whiskey
Exactly what had happened. I ended up changing plugs and wires and all is well.
Old 09-18-2010, 10:03 AM   #9 (permalink)
View cmaclean's Photo Gallery
Hey just thought I might say you may have the slippage again. A lot of the additives out there just swell the seals which will work for now. I would recommend getting it looked at or have the pan pulled to see if there is excess clutch/ seal/ bushing material in the pan.
Seen this all the time when i rebuild transmissions.
cmaclean is offline   Reply With Quote
