the plastic shroud under my toyota - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2010, 11:11 PM   #1 (permalink)
View rideat45's Photo Gallery
Canada the plastic shroud under my toyota
I've got a 99 corolla 1.8, after doing oil changes and having to work my way around that plastic shroud I was thinking is it a good idea to remove it, I can see the bolts that hold it up, but before I do that is there any rear purpose for it. Its plastic so its not a skid plate and it has openings, that lead me to believe its not there to direct air flow. Has anyone tried to remove theirs yet, if so how difficult is it?
rideat45 is offline   Reply With Quote
Old 09-11-2010, 11:38 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
I wouldn't suggest removing it. It's purpose is to help protect the engine from rocks, water, dust etc. It also plays a role in the aerodynamics, as the air can gush past without causing too much resistance/drag, which helps with fuel economy. It's easy to remove when the time comes to change your oil, as it should just be held in by a series of bolts, but I'd highly recommend putting it back on afterwards
Old 09-12-2010, 12:33 PM   #3 (permalink)
Gameroom cash: $201383
View teppista881's Photo Gallery
+1 to what Kiwi-Corolla says. It's held on by 6 10-mm bolts/screws--easy to get on and off.
teppista881 is offline   Reply With Quote
Old 09-12-2010, 11:07 PM   #4 (permalink)
View GreenYoda's Photo Gallery
Leave it, not saving weight and your not making any improvements so might as well keep that engine clean
GreenYoda is offline   Reply With Quote
