What else is on the dome light fuse( what else is drawing current on that circuit)?
You either have a short or your pulling to much current from the loads on the circuit/fuse.
Disconnect one load at a time when the fuse stops blowing you found your problem.
If that does not work and all loads are disconnected and the fuse is still blowing then you have a short in the wiring someplace.
You mentioned an amp and subwoofer if those were added to the circuit you are almost certainly overloading it. You can find out your current draw by either using a amp meter on the circuit or using ohms law.
What ever you do do not put a larger fuse in. The fuse is to protect the wiring not the load( light, speaker, amp).
