Mounted my Yellow Top. Properly. Without the frame. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2010, 06:26 PM   #1 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
Cool Mounted my Yellow Top. Properly. Without the frame.
Bonus for finding the one fine hackery that made it work.
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 09-25-2010, 07:09 PM   #2 (permalink)
View ProbeGT's Photo Gallery
Are you talking about the door still/kick plate or the socket used as a space on the far side
ProbeGT is offline   Reply With Quote
Old 09-25-2010, 11:21 PM   #3 (permalink)
Beware of pigs
Buurin's Avatar
Damn you're quick!
Door sill... So that's what it is. All I know is I found a nice straight piece of aluminum in the garage.
Buy my parts
Buy my other stuff
Old 09-25-2010, 11:45 PM   #4 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $614331
View Zembonez's Photo Gallery
Interesting use of the word PROPERLY
Zembonez is offline   Reply With Quote
Old 09-26-2010, 01:14 AM   #5 (permalink)
Originally Posted by Buurin View Post
Damn you're quick!
Im a carpenter and flooring installer, Im used to taking them out. Its fine one of the cars im active with has a much less aftermarket suppor then this gen of corolla. So we make alot of thing on our own things.
Old 09-26-2010, 02:09 AM   #6 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Ingenuity at it's finest . Nice idea. Looks like it works well.
Old 09-26-2010, 06:21 PM   #7 (permalink)
on full afterburner
Gameroom cash: $1345097
All that trouble to mount a battery.
Old 09-26-2010, 09:25 PM   #8 (permalink)
Beware of pigs
Buurin's Avatar
Well the yellow top came with a spacer frame that is clipped to the bottom to make it sized more like a regular group 35 battery as the battery itself is smaller although it is also a "group 35". Problem is even with the frame on, it's still smaller than the Energizer group 35 that I have and the factory bracket couldn't hold it firmly. I pulled some aluminum pieces from my scrap bin to pad up the gaps but they shook loose as well, probably lost somewhere in southwestern Ontario. So I decided to come up with a plan to bolt this down firmly, and while I'm at it, delete that frame that doesn't do anything but taking up space. And this is the result.
Interesting you talked about trouble. Imagine the trouble one has to go through to relocate it to the trunk.
Buy my parts
Buy my other stuff
Old 09-27-2010, 11:59 AM   #9 (permalink)
on full afterburner
I see... that makes sense.
How much does it weigh compared to the Energizer you had in there before?
Does it weigh more or less?
Old 09-30-2010, 01:53 AM   #10 (permalink)
Gameroom cash: $120800
View Milky's Photo Gallery
a trunk relocation is pretty easy. mine is in the trunk. took about 2-3 hours to do it. i prefer to run the 2 gauge wire thru the passenger compartment instead of under the car. i dont want to risk it eventually drooping, or getting snagged on some debris. the worst part was running the cable. and still its not hard, just time consuming.
Milky is offline   Reply With Quote
Old 09-30-2010, 01:38 PM   #11 (permalink)
Beware of pigs
Buurin's Avatar
I have extracted one ground wire along the entire length of the car; I think I can handle it. But that'll have to wait until I get a chance to turn a gutted ZZE110 VE into electric.
Buy my parts
Buy my other stuff
Old 10-01-2010, 03:58 AM   #12 (permalink)
my ground wire for the battery is less than 2 ft. only the positive needs to run that far.
also i want to see an electric 8th gen. that would be tits.
Old 10-01-2010, 02:55 PM   #13 (permalink)
Beware of pigs
Buurin's Avatar
http://www.evalbum.com/2673
http://www.thunder-sky.com/products_...fid=66&fid2=82
Where can I find a right controller that will allow me to drop these into my car? 90AH and it'll still be lighter than the Yellow Top.
Buy my parts
Buy my other stuff
