My 1998 Toyota Corolla won't start up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2010, 05:59 PM   #1 (permalink)
View 98corolla98's Photo Gallery
I have a 98 corolla CE automatic with about 152k miles on it and last night while I was parking my car I turned it off and decided to start it up again, but when i tried my car didn't want to start, so i took the key off and put it back in to start it up but didn't even make a crank noise to start up, I'm not sure if its the starter or the alternator that needs to be replaced
98corolla98 is offline   Reply With Quote
Old 09-26-2010, 06:43 PM   #2 (permalink)
pdq
Gameroom cash: $220900
View pdq's Photo Gallery
Most likely issue is your battery. You can take it to most any store that sells batteries and they can test it out with an amp draw tool before you replace it.
pdq is offline   Reply With Quote
Old 09-26-2010, 07:16 PM   #3 (permalink)
105
View 105's Photo Gallery
Also check and make sure there is no corrosion on the battery terminals. If so clean with baking soda and water.
1998 Toyota Corolla VE (A3 --> A4 swap completed 9-30-10)
105 is offline   Reply With Quote
Old 09-26-2010, 07:30 PM   #4 (permalink)
I replaced the battery 2 years ago but I will do that, also there is a bit of corrosion i'll be sure to clean that up right now and let keep posting with updates with my car and post pictures of my engine to get a visual
also,
thanks for the replies! I never get replies from other forums so this is a great help for the tips im getting
