2000 prizm(corolla) motor died, can i install a 2007 or 1998 engine? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2010, 09:11 AM   #1 (permalink)
View yoshiki2's Photo Gallery
is it possible? I can get any of those for a good price, but pp kep asking 1300 for a 2000 engine...
yoshiki2 is offline   Reply With Quote
Old 10-04-2010, 09:13 AM   #2 (permalink)
is the block head still the same? because i could adapt the other pieces.. all of them are corollas...
Old 10-04-2010, 02:36 PM   #3 (permalink)
View boxer4luvr's Photo Gallery
You might find this thread useful:
http://www.toyotanation.com/forum/sh...75#post3134975
We swapped an '06 bottom end into my 98 Prism. I've put almost 20k on it since then. purrs like a kitten.
good luck
boxer4luvr is offline   Reply With Quote
Old 10-04-2010, 06:12 PM   #4 (permalink)
Gameroom cash: $816401
View zythr's Photo Gallery
Probably because there were problems with this engine
zythr is offline   Reply With Quote
Old 10-04-2010, 08:27 PM   #5 (permalink)
Gameroom cash: $105620
View wylee's Photo Gallery
The 2007 long block is nearly a direct replacement for the 2000...you'll just need to use some of your 2000 sensors.
The 1998 does not have VVTi. The swap can be done, but would be a little more involved.
2010 Corolla S 5 speed. It's GONE!
2007 Corolla CE Auto
2010 Aveo5 - good CHEAP car so far
wylee is offline   Reply With Quote
Old 10-05-2010, 01:44 PM   #6 (permalink)
some1 is offering me 95 1.6 and 94 1.8 engines.. The first with 85k and the second with 120k.. Both for a really low price, what would I be replacing in both of them?? And which one would be easier to install? Thanks
Old 10-05-2010, 06:36 PM   #7 (permalink)
First make sure they're not having burning/using oil issues. Either one should not be too hard to install. I believe your car weighs more than the ones that the 1.6 and 1.8 liter were used in, so if this would work, your performance would be a little slower.
Old 10-05-2010, 06:47 PM   #8 (permalink)
How much is "some1" willing to pay you to take an engine that doesn't fit?
With the right amount of time, money, and , almost any engine could work.
Old 10-05-2010, 08:01 PM   #9 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
the A series engine 180 degrees reversed from the ZZ AND you'd have to rewire the whole car to make it work for less power and less fuel economy.
Old 10-05-2010, 10:13 PM   #10 (permalink)
lol, he wants 300 for the 1.8 from a 95 geo prizm.. any ideas in what will I need to install/fix? thanks
Old 10-05-2010, 11:34 PM   #11 (permalink)
can I use a 94 1.8 engine on a 2000?
sorry if am asking on the wrong chat, but maybe you guys could help me. Thanks
Old 10-05-2010, 11:42 PM   #12 (permalink)
BoyYota's Avatar
Gameroom cash: $138400
View BoyYota's Photo Gallery
It would be a major downgrade as they are not the same engines and use different computer and diagnostic systems. You would need to go from OBDII to OBDI which means swap out the whole wiring harness and ECU. Also there's stuff like gauge fitment, your gauges might use a different interface style so you might need to downgrade to old style gauges or use custom wiring.
94 Prizm LSi 1.8. Auto and still quick as hell.
BoyYota is offline   Reply With Quote
Old 10-05-2010, 11:58 PM   #13 (permalink)
Gameroom cash: $323345
View cipher93's Photo Gallery
It might mount up given I don't think the frame/suspensions are really changed between the 93-97 and 98-02, but the motor mounts are different, which leads me to believe the attachment points probably are too. However, the transmission will not work, you will need the harness spliced as mentioned, and that is assuming it mounts up which someone else could give you an answer on. No reason to do it at all and would be more expensive than just replacing it with the correct engine.
cipher93 is offline   Reply With Quote
Old 10-06-2010, 12:03 AM   #14 (permalink)
on full afterburner
Gameroom cash: $1345097
You should ask your local DMV in regards to specific emissions laws and swapping engines with older ones first.
Old 10-06-2010, 03:26 AM   #15 (permalink)
So he's only willing to give you 300 with the engine that won't fit? I'd try to get at least 2500 to help pay for making it fit.
Ideas on what you'll need:
Complete powertrain and dash wiring harnesses
Custom engine mounts
7th generation Corolla transmission
Custom transmission mounts
Custom axle shafts
That should get ya started....good luck
On a more serious note. Paying $300 for an engine that will require major fabrication and be an electronics headache is just plain foolish unless you've got time and money to burn.
This one would be a direct replacement after you stripped it down to a long block...and far cheaper:
http://cgi.ebay.com/ebaymotors/04-08-Toyota-Corolla-1-8-Liter-1ZZFE-Engine-OEM-LKQ-/200520333606?pt=Motors_Car_Truck_Parts_Accessories &fits=Model%3ACorolla|Make%3AToyota|Year%3A2008&ha sh=item2eaff17926
BTW
