Bearing rattle - PS, tensioner, idler, or water pump?
Friend's 1999 with manual trans ... about 120K.
Light bearing rattle at lower rpm, both parked and moving - as soom as steering wheel begins to be moved, it goes away - it does not occur when steering wheel is turned to full lock in either direction. Steering feels absolutely fine with no stiffness, etc anywhere. No squealing, no whistling, etc. Just light bearing rattle.
His mech replaced the belt and the tension assembly - same exact noise - although it did go away for 20 minutes. They have and used stetheocope. Are now recommending PS pump replacement.
I listened and since didn't have even basic tools, my assessment based only on this - I swear it seem to be coming from middle area of the accessory area - more like the idler pulley to the water pump area.
If it were my car, I would remove the belt and hand spin the various pulleys to see if one felt like it could be culprit ... but, since we live several hours apart, he will end up taking it back to his mech.
What do you think?
Thanks - appreciate the help and experiences from everyone!!
Stuart Stephenson
1999 Camry LE L4
1988 Jeep Cherokee L6
