Broken key in door - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2010, 06:52 PM   #1 (permalink)
View futureneck's Photo Gallery
Question Broken key in door
Well my wife broke the key in the drivers side door. fortunately it still works if you use a whole key, but i would like to fix this. Anyone know of the best way to do so. the key is broken about halfway down aprox 1 inch. thanks
futureneck is offline   Reply With Quote
Old 11-02-2010, 02:13 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
If you are lucky, might be able to fish it out with mini-jeweler's screwdriver.
I've used a straighten fishing hook in the past to extract a broken key - thin enough to fit between the pins and the key blank, and the barb on the end was just perfect to grab onto the soft metal of the key.
Otherwise, you'll have to pull the lock cylinder out and tap the old key out. Not sure if they still have a little hole in the back of the lock cylinder to push a broken blank out.
The Following User Says Thank You to fishexpo101 For This Useful Post:
2004 (01-01-2011)
Old 11-12-2010, 09:41 AM   #3 (permalink)
thanks for the help fish. i tried fishing it out with a hook and tweezers. the issue is the little flap that closes the entrance to the lock. i cant get that pushed back and have enough room to take out the key. is anyone aware if these door locks have a small hole in the back to tap out the key fragment? oh btw its a 2001.
Old 11-12-2010, 12:04 PM   #4 (permalink)
30 yrs of Car Photography
hairball's Avatar
View hairball's Photo Gallery
These usually work quite well...
By the way, "Hairball" was a cat of mine.
Since I don't use the "GameRoom", can you just send me a check?
hairball is offline   Reply With Quote
Old 12-05-2010, 01:04 PM   #5 (permalink)
sorry but what ever you posted in the pic there isnt showing up.
