No check engine light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2010, 09:33 PM   #1 (permalink)
View ashu's Photo Gallery
Hi Guys,
I have just installed remote starter in my toyota corolla 2002,this morning it start ok.but when i did on heater,engine stoped.I did check battery connection every thing is ok.When i do put key for manual start it does not start even do not show check engine light on dashboard and no crancking no noise at all.but when i try to start with remote start it only cranck but engine would not start please help me.
Thanks
ashu is offline   Reply With Quote
Old 11-16-2010, 10:38 PM   #2 (permalink)
View 1.8litrebeater's Photo Gallery
How do you have it wired up? it sounds like one of your ignition wires is no hooked up right or a fuse is blown. Post a pic of your wiring if you can
98 Corolla CE
1.8litrebeater is offline   Reply With Quote
Old 11-16-2010, 10:59 PM   #3 (permalink)
Thanks for reply,All the wiring is done by a installer whom i found on kijiji,after installation car was worked well for three days if you could tell me which realy or fuse i have to check or ignition wire i can check it.
Thanks
Old 11-17-2010, 04:10 PM   #4 (permalink)
Gameroom cash: $116400
View Clayton1984's Photo Gallery
Probably the result of a shoddy wiring which grounded out. One or more fuses is probably blown, but replacing it will only be a temporary fix at best... no fix at worst. You need to have the system rewired by a competent individual. Hopefully you haven't fried anything.
Clayton1984 is online now   Reply With Quote
Old 11-17-2010, 06:40 PM   #5 (permalink)
I did check all the fuses with the test light they are ok couple does not ok but seems ok in side means no blown contact.Can you guys tell me where is main ecu or ecm fuse can not find.I also did check fuses under the steering only one is not working check the fuse contact are good.Please guys advice me soon can not pay for taxi every day for work.
Thanks
Old 11-17-2010, 07:52 PM   #6 (permalink)
I'd call around to nearby reputable businesses that have experience installing your particular remote start to arrange for your vehicle to be towed to their location for them to have a look at the install to check for any problems.
OR
To a nearby reputable mechanic who professes to have experience with remote starts in Toyota's.
