FINALLY found source of oil usage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2010, 03:37 PM   #1 (permalink)
View spingley's Photo Gallery
Well after months of trying to figure out why my 2000 Prizm was going thru oil like there was no tomorrow, it turns out the oil filler cap was bad. I had pulled the plugs after doing a search on this site for oil usage but they looked almost like new, I could not see any oil dripping from the engine anywhere but around the oil filler and I assumed that was from when my wife was adding oil she was just dumping it, but found out she had been using a funnel. Then a friend mentioned that he had a car that had a bad cap so I looked at the filler cap and the rubber gasket was dried up and shrunk back into the cap and was doing nothing. Next I started the engine and removed the cap and the back pressure was actually slowly pushing a film of the oil up the sides of the hole and spraying it out, not a lot mind you but add up hours of driving and it can be significant. Two of the many quarts of oil I have put in there would have paid for the new cap from Autozone, if I had only known!! Now it hardly uses any oil at all.
spingley is offline   Reply With Quote
Old 11-20-2010, 04:31 PM   #2 (permalink)
heartdisease's Avatar
Gameroom cash: $113370
View heartdisease's Photo Gallery
How many miles does your car have? I had an old escort that would push oil up into the carb intake and kept oiling the air filter. It got really bad before I sold it. I think it was the valves seals as the pcv was replaced regularly.
heartdisease is online now   Reply With Quote
Old 11-20-2010, 06:49 PM   #3 (permalink)
About 112k, I was wondering if there should be any blowby with the engine running and the filler cap off, it really doesnt feel like a lot, but its there.
Old 11-21-2010, 06:32 PM   #4 (permalink)
Bdub215's Avatar
Gameroom cash: $316765
View Bdub215's Photo Gallery
did you see any smoke? there will always be crankcase pressure with the enigne running. granted their are probably other ways to check but thats the main way i know of. im at 185k and have no blow-by suprisingly.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 11-21-2010, 11:12 PM   #5 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
spingley: Sounds like you should have your vent hoses and the PCV valve checked out too.
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 11-22-2010, 08:50 AM   #6 (permalink)
I think I'll do that, thanks.
