Wiring lock/unlock with aftermarket alarm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2010, 08:50 AM   #1 (permalink)
View bigphil0011's Photo Gallery
Hi, this is my first post on this forum. I have a 1999 Corolla LE.
I purchased an autopage remote start that has a lock/unlock feature on it. I've figured out where and what wires to make the appropriate connections with it except the door unlock/lock. The autopage unit has 2 wires for lock/unlock triggering. I've looked at various sites and have come up with several different answers to wiring up the autopage unit.
This information has two separate wires for lock and unlock, should I just wire them straight to these wires? Do I have to do anything with the lock motor wire, or the door trigger wire?
thanks in advance for the help!
POWER LOCK BLUE/BLACK (TYPE B) See NOTE *1 @ WHITE PLUG, RIGHT SIDE of FUSEBOX
POWER UNLOCK GREEN/WHITE (TYPE B) See NOTE *1 @ WHITE PLUG, RIGHT SIDE of FUSEBOX
LOCK MOTOR WIRE BLUE (+) IN DRIVERS KICK PANEL
DOOR TRIGGER RED/WHITE (-) @ INSTRUMENT CLUSTER or See NOTE *2
bigphil0011 is offline   Reply With Quote
Old 11-24-2010, 10:14 AM   #2 (permalink)
After doing a little more digging around here, it seems that I can just connect those two wires, and as long as they ground the signal it should operate the locks. Is this correct?
