2000 Corolla cyl #2 misfire
I see someone right before me is having the same issue, but i figured I wont jack his post.
I bought the car how it is. When you put it in gear, the car idles waay down almost to where its going to die, check engine light is on for a cyl 2 misfire. I was told the cylinder order from standiing in front of the car looking at the motor is 1-3-4-2
i checked all the plugs, all the plugs were dry except for the #3 (according to my numbering) which was oily and black. I bought a new coil pack for $100 and swapped it with, the #2 and the one that was all oily, and reset the code both times, and both times it came back up and ran the same. So now do i replace the injector or is there something that normally goes out that i dont know about?
