just under 186k and when i happen to rev it today and it throws out a cloud of blue smoke from the muffler. not good. eating way to much oil.
so i pull it into my garage and do a compression check
Compression pressure:
1,500 kPa (15.3 kgf/cm2, 218 psi)
Minimum pressure:
1,000 kPa (10.2 kgf/cm2, 145 psi)
Difference between each cylinder:
100 kPa (1.0 kgf/cm2, 15 psi) or less
^ as my refrence
first run across
150,150,150,160
then w/ a little oil
150, 160,170,160
still in spec but from the RM "If adding oil helps the compression, it is likely that
the piston rings and/or cylinder bore are worn or
damaged." willing to bet i have all 3. and my bumper is black now. and ideas on how to proceed from here?
