tire up grade - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2010, 01:44 AM   #1 (permalink)
View jtaka's Photo Gallery
tire up grade
i have a 2000 corolla with 14 inch rims. any suggestions on rim and tire size i can use. looking to go with a 15 inch rim. also looking at sumitomo htr as po1. anyone ever use these tires. the sumitomos got a great write up on tire rack. well thanks in advance.
jerry
jtaka is offline   Reply With Quote
Old 12-06-2010, 07:53 AM   #2 (permalink)
Gearhead
Gameroom cash: $196215
If you are looking to go to a 15" - then a 15x7 wheel (4-100 bolt pattern, 35-40mm offset) should do the trick. Tires - want to stick with a 195/55-15 tire. You can go a little wider, 205/50-15 - but that will through off you speedo a bit (vehicle speed is lower than indicated, about a 1MPH difference at 60MPH).
Sumitomo HTR A/S PO1 should be a decent tire. Ran Sumitomo's before, little on the "soft" side compared to other tires in its class, so handling may be a little less sharp, but traction is well rated and better than others. Seems to be a fairly new tire, so decent reviews may take some time to filter in, for the time being they seem pretty positive.
Old 12-06-2010, 10:15 AM   #3 (permalink)
Thanks for the tips on tires and rims. Now I know what to ask for xmas from my wife. I think I will call tire rack and bend their ear about those Sumitomo tires.
Thanks
Jerry
Old 02-24-2011, 11:03 PM   #4 (permalink)
I am still looking for a 15 rim that will fit on my 2000 corolla. Are there any stock wheels like from honda, mazda etc that will fit. Also what dimesion should I look for. I have read I should look for 4x 100. is this a size. Also what width do I look for. I dont want to make any modifications on my sons car.
jerry
The Following User Says Thank You to jtaka For This Useful Post:
super bh (02-25-2011)
Old 02-25-2011, 10:38 AM   #5 (permalink)
Gearhead
jerry
This is what you should be looking for, already mentioned above in my earlier post
- 15" wheel, 7" width maximum
- 4x100 is the bolt pattern, it means 4 lugs, 100mm bolt circle
- 35-40mm offset is the distance between the mounting hub and the centerline of the wheel. Most FWD vehicles will use a positive offset, most RWD vehicles will use a negative offset.
As long as you look for a FWD car with 15" wheels and 4x100 bolt pattern, there is a good chance that it will fit the Corolla. Otherwise, I'd just hit up Tirerack or similar and get new wheels and tires. If you get a package, they will mount the tires and balance the wheels for you - just bolt on and go. I've done this with my other vehicles and have never been dissatisfied with their work.
Old 02-26-2011, 02:20 AM   #6 (permalink)
**BosnianRamboo**c
View BosnianRambo's Photo Gallery
I have 15s and im using Tires 205/50 Generals...very good tires! Its the best set up i had up to now.
BosnianRambo is offline   Reply With Quote
