Those are the harnesses that connect to the connector directly under the panel for your side mirror. If you peel back the weather shielding sheet there is a little connector that is for your speakers, and this fits in there. In my opinion, you really don't need it, and I would just suggest cutting the wire at the speaker.
As for an adapter, yes, you might want to get one. I actually just dremel'd the old adapter and took off the magnet, drilled into that, and placed my speaker in there. I then just used some sheet metal screws instead of rivets, because personally, I have no clue how to do riveting. lol.
But yes, 6.5's fit, I just did mine yesterday. 5.25's also fit, but I would recommend just getting some 6.5's.
