98 corolla reverse/neutral and power window issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2010, 05:44 PM   #1 (permalink)
View viper_cole's Photo Gallery
I'm having a few issues with my wife's corolla, there was a transmission leak on one of the hard lines which I found and repaired with rubber AT hose, topped it back up and for some reason when you shift it into reverse it just revs to about 2300 rpm, normally thats mean rebuild... however when I put it in neutral the car drives forward, all the other gears drive the car forward, I'm thinking there is some stuck valves, so I'm going to try a flush and filter to see what comes out of that.
Also the window does not go up and down properly I think the motor is overheating, causing an internal breaker to let it cool down then continue going up, does anyone else have some ideas on the driver window issue, or the problem with the transmission, (might even need to adjust the shift linkage)
viper_cole is offline   Reply With Quote
