Exhaust - What is This? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2010, 12:48 PM   #1 (permalink)
105
View 105's Photo Gallery
There is a ring welded over this part of the exhaust that is pointed out in the picture. Right now its loose and rattling all the time. Can I get rid of it is it serving a purpose?
1998 Toyota Corolla VE (A3 --> A4 swap completed 9-30-10)
105 is offline   Reply With Quote
Old 12-20-2010, 08:10 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
well if its loose and rattling its no longer serving a purpose...
Old 12-21-2010, 05:22 AM   #3 (permalink)
Gameroom cash: $120800
View Milky's Photo Gallery
that is needed to connect the rest of the exhaust to the downpipe. what is rattling isnt that ring, but the clamp on it. the clamp could be loose. hell it could be missing for all i know. but you need it. think of it as a oem toyota style vband flange, but its not a true vband. the cat pipe butts up to that "ring" then a clamp that is form fitted to the ring/catpipe goes over the joint and seals it/hold it together.
shit i just realized your local. i may have a spare downpipe somewhere. if you need it let me know. cus you can have it.
Milky is offline   Reply With Quote
Old 12-21-2010, 07:31 AM   #4 (permalink)
105
Thats what I was afraid of. I'm guessing this is happening because I had a straight pipe welded in place of my cat. If this "clamp" is only holding the pipes together couldn't I just figure out a way to hold it still? The only way to remove it is to cut it off. I'm gonna get a picture of the actuall situation posted soon.
Old 12-21-2010, 05:41 PM   #5 (permalink)
105
Pics are now posted above.
I see what you mean now though. I got under the car with it running and could feel an exhaust leak coming from there also. That explains why I smell fumes every time when I run my heat.
So more importantly, what would be the best solution to fix the leak. I'm thinking just get the stupid clamp removed and get the shit welded.
Was that clamp attached in some other way before? Like when the cat was still connected. Maybe I can get the shop to fix it for free if it is something they did wrong.
Old 12-21-2010, 06:10 PM   #6 (permalink)
ロンリードライバー
Gameroom cash: $224935
View all2baka's Photo Gallery
You're running without a cat?
all2baka is offline   Reply With Quote
Old 12-21-2010, 06:58 PM   #7 (permalink)
View viper_cole's Photo Gallery
running w/o a cat is just a bad idea, but your choice non-the less, depending how bad the leak itself is, try using muffler cement to fix the leak, and use a die grinder to remove the clamp if it is still there
viper_cole is offline   Reply With Quote
Old 12-21-2010, 09:21 PM   #8 (permalink)
105
We don't have emissions testing here. I got rid of the cat because it was going bad anyway and throwing a code. Why spend a bunch of money for something that will fail again. The car isn't much louder. Its also simple to fool the rear o2 sensor.
Old 12-22-2010, 01:32 AM   #9 (permalink)
the best and simplest solution is to just replace the clamp and pipe, if they are bad like you think. you might want to check them, the clamp could be just loose. there are also 2 gaskets for the downpipe. a donut gasket for the manifold to downpipe and a odd o ring style one for the clamp connection. if you want you can have my spare downpipe and mild ported manifold. they are both just sitting, taking up space. i want them gone. all you would need is the gaskets. which can be ordered from toyotapartszone.com IIRC for cheap. the whole swap of a manifold and downpipe takes like 20-30 minutes. provided the clamp is in good shape.
Old 12-22-2010, 07:39 AM   #10 (permalink)
105
I'll give the parts a try. I'm still thinking the shop that removed the cat tampered with that clamp. Is that clamp supposed to bolt on? Because mine is welded. I'll need a new clamp if I replace the downpipe since I'll have destroy the clamp to get it off. I wish I could remember what it looked like under there before the cat delete.
Old 12-22-2010, 01:22 PM   #11 (permalink)
yeah the clamp is supposed to be bolted on. it has a stud with a nut on one side. it does sound like the shop messed up. not surprising at all. the stud has a tendency to break if its the first time coming off since it was installed. but you can easily knock the stud out with a hammer and use a bolt, couple washer and a nylon lock nut. this is how mine is now. i dont think i have a spare clamp, but ill check.
Old 12-22-2010, 01:34 PM   #12 (permalink)
105
If you don't have it, I found it at the website you linked.
Diagram
http://www.utoyot8.com/FullImage.asp...8&ppInfo=(9708-++++)
It looks like the clamp is either 17452 or 17452A, what do you think? I'm thinking 17452A.
Gasket is 17451.
http://www.toyotapartszone.com/Page_...onentsIndex=17
Old 12-22-2010, 03:10 PM   #13 (permalink)
yeah that is the part number, but without the A at the end, as seen in the lower pic. and for 5 bucks that kinda cheap. i love that site, they always have great prices. i have bought so much oem parts on there during my engine rebuild.
Old 01-22-2011, 02:34 AM   #14 (permalink)
View moviestar's Photo Gallery
if they don't peak under the car for emissions....youre car will still pass an air quality test without one (i run an empty shell and pass emissions yearly with flying colors) it adds minimal hp/tq because of how low powered our engines are anyway but an upgrades an upgrade...
moviestar is offline   Reply With Quote
Old 01-23-2011, 01:33 AM   #15 (permalink)
true, but their are other contributing factors that help this. like the staggered cam setup, higher compression, vvti and the longer stoke of the 1zz. both of these allow for longer burn time of the air fuel mixture. more so the long stroke. the staggered cams trap a bit of unburnt exhaust in the chamber. this is because there is less lift and duration on the exhaust side. vvti can play into this as well by closing the intake valve sooner.
