starting problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2010, 07:10 AM   #1 (permalink)
View anxious's Photo Gallery
starting problem
My corolla 2001 LE could not be started after two freaking cold days without running. I replaced new battery for it, but no help. Could anybody give any tips on it? Can I start it with jumper from another car?
thanks now
anxious is offline   Reply With Quote
Old 12-21-2010, 04:43 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
If the new battery is not doing it, then a jump will unlike help out.
Need more information - what do you mean but not starting?
Does the car make any clicking or ticking noises when you turn the key to start?
Is the car cranking but doesn't run?
Anything else electrical that is not working?
Checked to make sure there is gas in the tank?
Checked oil levels?
What is the maintenance history of the car?
If the weather was really cold, another possibility could be a frozen gasoline line. A bottle of gas drier will help out very quickly in that case.
The Following User Says Thank You to fishexpo101 For This Useful Post:
anxious (12-22-2010)
Old 12-22-2010, 08:17 AM   #3 (permalink)
Thanks, fishexpo101.
The car did make clicking or ticking noises when I tried to turn the key to start. Could it be the bad starter?
Old 12-22-2010, 08:33 AM   #4 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Was it a single click each attempt ?? or rapid repeated clicking ?
If single click I would try it several times to see if it will start at some point.
If rapid clicking and dimming dash lights check voltage level of new battery and connections.
CraigW is offline   Reply With Quote
Old 12-22-2010, 08:34 AM   #5 (permalink)
View viper_cole's Photo Gallery
if the car is making a clicking ticking noise, that usually means the starting system is good upto the solinod, however it would be worth while to have your battery tested to make sure it still has the right amount of CCA's, you can also jump the starter, or if your car is manual push/pull start it
viper_cole is offline   Reply With Quote
Old 12-26-2010, 02:16 PM   #6 (permalink)
thx to all replies. Oops, my friend told me that could be caused by the bad fuel pump? Can it be true?
Old 01-01-2011, 09:25 AM   #7 (permalink)
View kappy's Photo Gallery
I would say no to the bad fuel pump, unless it was cranking over for some time, and would not start because you killed the battery trying to start it. If you just have one click when u trun the key. sounds like the starter or solinoid.. Had the same issue, tested neutral safety switch, relays.and starter it was the starter, put the new one in done.. first make sure the battery is charged and holding a charge. after I put my starter in, 3 days later more clicking and would not turn over.. drove me nuts to figure this out.. believe it or not, ended up being a bad starter they sold me.. at least it only took me less than half the time to put another one in. good luck
kappy is offline   Reply With Quote
Old 02-13-2011, 07:29 PM   #8 (permalink)
View modestobulldog's Photo Gallery
Sounds like a bad starter, this may help:
Weird Starter Problem
modestobulldog is offline   Reply With Quote
Old 02-15-2011, 09:31 AM   #9 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
could be? could be many things?, relay? starter control circuit? bad cable? ground?
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
Woodyg is offline   Reply With Quote
