98 corolla 5S-FE swap?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2010, 01:36 AM   #1 (permalink)
View golana's Photo Gallery
i have a 98 corolla, and she burns oil like its going out of style!
i drive the bag off my car and im not going to stop, so im thinkin a motor swap will be my best bet...
i was told by a coworker that the 2.2L 5S-FE camry motor will bolt up to my corolla tranny... anyone heard of this?
1998 Toyota Corolla CE Limited - stock
1994 Toyota 4Runner - Solid Axle Swapped, 5VZ-FE, 12" Lift, Twin T-Cases, 33's, Hydro Assist, Ford Fuel Tank (w/Toy pump and sending unit), Rear Disc Brakes, IFS Mod + Big Brake Mod, etc...
1985 Toyota Pickup 4x4 - RIP
golana is offline   Reply With Quote
Old 12-22-2010, 02:10 AM   #2 (permalink)
Gameroom cash: $120800
View Milky's Photo Gallery
no it will not. your coworker is an idiot. now people have done the better 3sgte swap into a corolla. like the 5s swap it requires wiring harness, ecu, engine, trans and a whole lot of time and money.
the easier swaps are all of the zz family. only a zz engine will bolt right up to our trans. period.
Milky is offline   Reply With Quote
The Following User Says Thank You to Milky For This Useful Post:
golana (12-22-2010)
Old 12-22-2010, 02:13 AM   #3 (permalink)
Originally Posted by Milky View Post
no it will not. you coworker is an idiot. now people have done the better 3sgte swap into a corolla. like the 5s swap it requires wiring harness, ecu, engine, trans and a whole lot of time and money.
perfect! thanks a lot for that info! any recommendations for something that would be fairly easy to swap in... i am sick of putting in a qt every week or two (seriously!!!)
Old 12-22-2010, 02:18 AM   #4 (permalink)
just did some quick searching, and i guess the other zz motors make less hp, unless its the 2zz-ge from japan... i dont have that kind of money, so im wondering if maybe i could just rebuild my 1zzfe and get bigger pistons...?
do many (any) people bore these motors out at all?
actually!!! the pontiac vibe uses a 2zz-ge! i wonder how much i could scoop up one of those motors... i work at a autowreckers, so i can get pretty good deals
Old 12-22-2010, 03:19 AM   #5 (permalink)
you can build a 1zz. or swap to a 2zz. it has been done before. you said you work for an autowreckers so i dont think finding the engine would be a problem.
not many bore them out, because to go to a larger bore requires the block to be sleeved. but if your interested in building the 1zz or 2zz then i suggest checking out monkeywrenchracing.com they have built a 500+ whp 1zz and a few 600+ whp 2zz. so they are quite capable engines. just not very cheap to build.
the 2zzge came in 00-05 celica gts's, matrix / corolla xrs's and pontiac vibe gt's as well as the lotus elise and exige. all the 2zz manuals are a 6spd close ratio trans. with the right parts, the trans can be swapped in to your corolla with the stock 1zz. it makes the car extremely fun. i know, my corolla has a 6spd.
Old 12-22-2010, 01:38 PM   #6 (permalink)
thats awesome! thats exactly what im going for! i want a 6spd in my corolla. i know we have a few pontiac vibes and matrix's at work. im sure i could pick up a complete motor and everything pretty cheap. i want to get the 2003 vibe motor, cause it has the most hp, sitting at 170. in 04, they went down to 163, and after 05, they were at like 154 or something
so what all was involved in your 6spd swap? what right parts are you talking about?
Old 12-22-2010, 03:04 PM   #7 (permalink)
you need to use axles from a 00-05 celica gts. the thing is they are a equal lenght half shaft setup, which uses a carrier bearing/support brace that connects to the exhaust side of the engine to help support the intermeadiate shaft. our blocks do not have the holes drilled for this. all celica 2zz and 1zz engines do tho.
other than that, you will need the shifter cables from a 00-05 celica gt/gts. provided you are allready a 5spd. if your not then you will need everything to do a complete trans swap, which would include these spefic parts. the gears are really close together. like almost stupid close. top speed is 127mph in 6th with the stock 6250rev limit. and it will get there pretty quick. if you can get a 03+ 6spd because they have wider shift gates and this means less missed shifts/over revs.
also the celica gts is the most powerfull US 2zz, with 180 hp and 8400 rpm rev limit in the 00-02 gts's.
Old 12-22-2010, 07:07 PM   #8 (permalink)
Gameroom cash: $816401
View zythr's Photo Gallery
Or sell it and get a later model Corolla
zythr is offline   Reply With Quote
Old 12-23-2010, 01:06 PM   #9 (permalink)
Bdub215's Avatar
Gameroom cash: $316765
View Bdub215's Photo Gallery
5s-fe in a corolla? im at a loss for words....
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 12-23-2010, 01:08 PM   #10 (permalink)
haha, just going off what i heard from a coworker. im going with a 2ZZge now
Old 12-28-2010, 10:51 PM   #11 (permalink)
View TwoPageAfro's Photo Gallery
Sorry, Milky I'm confused... do you have the 2zz swap with the 6spd or the 1zz with the 6spd?
TwoPageAfro is offline   Reply With Quote
Old 12-29-2010, 08:16 AM   #12 (permalink)
View dorman68's Photo Gallery
Use a low mileage short block from an 04 or newer car(Vibe,Corolla, Matrix) with a 1zzfe. The later cars have revised pistons and rings to eliminate the oil consumption issue.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 12-29-2010, 08:36 AM   #13 (permalink)
i have a 1zz with a 6spd.
