Heater does not work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-24-2010, 03:37 PM   #1 (permalink)
View dballard18's Photo Gallery
I have a 2002 Toyota Corolla. I have vented the cooling system, however the heater does not work. The heater door is opening, the top heater hose is hot, the bottom heater hose is colder. I have replaced the water pump and thermostat as a PM move as the car has 144,000 miles. I flushed the cooling system, including the heater core and refilled with new antifreeze. The heater does make one quick blast of hot air then turns cold.
dballard18 is offline   Reply With Quote
Old 12-25-2010, 02:07 PM   #2 (permalink)
View viper_cole's Photo Gallery
is the motor blowing air? there are a few things it could be.
air in the system (heater core is highest spot)
blocked heater core
bad t-stat
remove the rad cap / pressure cap and let the air bubble out while topping up the anti-freeze, make sure the heat is max and the fan is on high,
(this will help with bleeding)
to check the heater core remove one line and blow air into it, and depending on how many bubbles come out the other end then its not block (or not blocked badly) and the t-stat can be tested with boiling water, thermometer (so you can see the temp of the water) and it should open up at the temp rated on the t-stat normally 195 degrees
viper_cole is offline   Reply With Quote
Old 12-25-2010, 06:02 PM   #3 (permalink)
Heater fixed
I spent the day on the car. Pulled the thermostat and all heater hoses, flushed everything with a garden hose. I verified the air doors were opening. Still had cold air.
The end of the story, I accepted that I had some pluggage of the heater core, more than the little water pump could overcome. I pulled the heater hoses again, flushed the heater with water, blew out with air then backfilled the heater with Liquid Plumber. After 15 minutes, I rinsed and repeated the liquid plumber. Then I rinsed and vented all of the air, and hooked everything backup.
The heater is fine now!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 12-26-2010, 11:21 AM   #4 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
THIS IS EPIC!
Congrats for getting that fixed and thanks for this tip. This needs to live on,
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 12-26-2010, 12:35 PM   #5 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
did the liquid plumber seem to take out alot of crud?
Old 12-28-2010, 04:56 PM   #6 (permalink)
I flushed it slowly at first, there seemed to be some brown water, no clumpy stuff.
Old 12-29-2010, 08:59 AM   #7 (permalink)
Gameroom cash: $120800
View Milky's Photo Gallery
i got to say i just died laughing when i saw the liquid plumber. as funny as it may be, if it worked then good job.
Milky is offline   Reply With Quote
Old 12-29-2010, 11:06 AM   #8 (permalink)
I would laugh as well. It was either a "Think Outside the Box" or undertake a big job. And it worked VERY well, a $4 bottle vs. Parts and Labor, it was worth a gamble. I never had any luck with the flush chemicals available at the parts houses. BTW, I had the heater fully disconnected, all hoses off when I did this.
Old 12-30-2010, 02:21 PM   #9 (permalink)
An Update on another vehicle
I have another vehicle, a Dodge Dakota, daily driver with 405,000 miles. It too had a heater that was not working very well. The temperature as measured at the upper vent was about 75 on a low fan speed. No much on a high fan speed. It was very chilly truck in Ohio on a cold day.
I disconected the heater, flushed with water, blew out with air, then backfilled with Liquid Plumber, did this twice. I believe a key here is to blow out with air so the entire heater was saturated with the chemical upon backfilling. Flushed again very well with the garden hose.
The temperature now as measured at the upper vent is 115 degrees with the fan on HIGH.
I saved another $1000 job with a $4 bottle. I am laughing all the way to the bank...... And staying warm in Ohio.
Old 12-30-2010, 05:01 PM   #10 (permalink)
Beware of pigs
Buurin's Avatar
a Dodge Dakota, ... It too had a heater that was not working very well. ...
I disconected the heater, flushed with water, blew out with air, then backfilled with Liquid Plumber, did this twice... Flushed again very well with the garden hose.
So very true. Liquid Plumber, the two-hit wonder.
Buy my parts
Buy my other stuff
