2002 corolla idle problems. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2010, 09:27 AM   #1 (permalink)
View tinted's Photo Gallery
Post 2002 corolla idle problems.
hey guys,
i currently have a 2002 corolla with 290 000 kms on it. till today it ran really well. but it idles really rough all of a sudden, kind of a deep raddle. and when i get to higher speeds(80 km/h) the whole car starts to shake alot.
dose anyone know the problem or how to fix it?
thanks in advanced for all the help!!
tinted is offline   Reply With Quote
Old 12-29-2010, 01:30 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Could be a number of things causing that. Anything replaced or changed out recently? Spark plugs changed recently - car is pretty sensitive to spark plug quality, plugs could be fouled or just plain worn out? Started after you filled up the tank - could be a bad tank of gasoline, try a different gas station to rule that out? Vacuum leaks, exhaust leaks, induction leaks can also cause funny driveability. Faulty of clogged injectors are another possibility.
Did you notice a check engine light come on when this happens? Sometimes the CEL will flash and not stay on.
Things to check:
- Spark plugs, even if you changed them recently, pull them and read the ends. Note if anything looks different from plug to plug. Note any deposits, discolorations, wet/dry, etc.
- Oil level - double check motor oil levels. Some of the 1ZZ-FE engines on the 8th gen Corollas have turned out to be notorious oil burners. Some start very suddenly, so it is a good idea to check the oil
level as often as you can (every fillup).
- throttlebody and MAF sensor, MAF can get covered by deposits, more so if you have a free-flowing filter design. Cleaning it and the throttle body can greatly improve idle quality and drivability.
- Add a bottle of decent fuel injector cleaner - something like Redline SI-2 Fuel System Cleaner is what I like to use.
Tags
corolla, idle problems, shaking
