What could be draing my battery - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2011, 09:31 AM   #1 (permalink)
View kappy's Photo Gallery
have a 99 corolla automatic, went out battery dead, had it tested done,
put a new one in, 3 days later dead, does hold a charge, put it back in.
tested the amps while running 14.8 good right. put a load on it, lights heater, radio, still good load of 14.7 that shows me the alternator is doing its job. what can it be. it is reading 12.8 with the car off, I am going for a ride today, and check the amps when I get back.. any thoughts be appreciated.
kappy is offline   Reply With Quote
Old 01-04-2011, 02:21 AM   #2 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
If your charging system is working right, then you have a high drain on the battery when the ignition is turned off. Turn the ignition off and disconnect the negitive battery terminal form the battery and instal an amp meter in series ( between the negitive battery terminal and the and the battery ground wire) with the battery( you can use an amp clamp too). If its higher that 200 milliamps you have a short somewhere. If you find a high current draw ,try unplugging/ disconnecting your alternator first.
sam333 is offline   Reply With Quote
The Following User Says Thank You to sam333 For This Useful Post:
kappy (01-07-2011)
