Oil Light On - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2011, 07:22 AM   #1 (permalink)
View brooklyn99corolla's Photo Gallery
Oil Light On
The oil light on my 99 corolla started to blink and stay on, oil level is fine and oil gets changed every 3000 miles, it has 97,000 miles. Is it safe to drive with the light on? anyone know what could be wrong or what needs to be checked or fixed?
1999 Toyota Corolla CE
2005 Tahoe Z71 - 22" Liquid Metals-Western Ultimate
Bull W/PIAA 520-OEM NavW/6 Disc Changer - Every Available Option
2007 Infiniti QX56 - 22" Konig Rolf Blix - Every Available Option
brooklyn99corolla is offline   Reply With Quote
Old 01-03-2011, 07:55 AM   #2 (permalink)
View Highway_maniac's Photo Gallery
Oil light on = oil pressure low. It does not mean to little oil, though to little oil will result in loss of presure.
Maybe something is blocking the flow of oil - oil filter or sludge.
Other possibilities, your oil pump is failing of your oil pressure switch is acting up. I would have it checked at the garage.
Highway_maniac is offline   Reply With Quote
The Following User Says Thank You to Highway_maniac For This Useful Post:
brooklyn99corolla (01-03-2011)
Old 01-03-2011, 08:02 AM   #3 (permalink)
Thanks Highway! was thinking the same thing, can i check with the OBD scan tool or is there another way to check?
Old 01-03-2011, 08:46 AM   #4 (permalink)
Don't know if you can read oil pressure through OBD, no experience. You could connect an oil pressure gauge to check the pressure.
Maybe a mechanic has some tools to check the pressure, if it's OK, first thing I would do is to replace the oil pressure switch.
Old 01-03-2011, 09:16 AM   #5 (permalink)
Thanks i'll do that first since the part is between $10-$20, do you have any idea where the switch is located?
Old 01-04-2011, 07:10 AM   #6 (permalink)
View dorman68's Photo Gallery
The switch is located right above the oil filter.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 01-04-2011, 11:11 AM   #7 (permalink)
Thanks Dorman! you the same dorman from Z71??
Old 01-05-2011, 07:09 AM   #8 (permalink)
No problem! Glad to help out. I belong to several forums, if you mean Z71 TAHOE/SUBURBAN.COM, then yes I am registered there too.
