Try this.......!!!!!!!!!!!!
HEY YOU Deadly Sushi check this out....!!! my 2001 corolla ce also has the same problem.... mr,#2 misfire . i called my buddy up and we check fuel injector, ignition coil, spark plugs and mr 1,2,3,4 compression......guess what everything seems fine.....if the same goes to you dont worry about it ....i got mr#2 misfire fix. how ? well i notice #2 cylinder spark plugs were dry and seems like its not getting fuel....OK ALRIGHT ......so i check the fuel injector wire ....!!!!!bam one wire gave up and snap .....make sure you check deep within the wires to see if anything is torn .......dude hope this help man .............. so me and my buddy solder the wires ...bam the car runs smooth now...... one big lesson i learn from this, never over look the the little stuff........
