'99 Corolla Starter/Ignition Switch Issues
'99 Corolla VE 160k Original starter, 3 week old battery.
Been having on and off again issues with the starter either not kicking in(single click noise) or kicking in and staying engaged when the key is turned to the start position and then released after the engine is running. Other times it works normally. This is over the last month or so.
Tonight we went out to start the car and we engaged the starter and the engine tried to start but the starter kept on running even after the key was removed. We didn't have any tools handy to disconect the battery and I didn't remember if there was a major fuse to pull to kill power to the system. The engine makes a very funny rattling sound when that occurs It didn't take but maybe a few minutes of the starter running on its own to totally drain the battery; .34 volts according to the VOM(since now that tools have arrived). This has happened once before when the battery was fresh and the starter remained engaged after the key was returned to the normal on position, but quit when the key was removed. . By jump starting the car with another the starter still kicks in once the final jumper cable lead is connnected. Maybe tonight's failure is its final failure.
My questions are as follows:
1. It certainly sounds like the ignition switch is acting up here, but could there be anything else causing these symptoms? Don't want to replace a good starter or ignition switch assembly and not have it solve the problem and then have to spend more money.
2. Could there be a relay acting up or a fuseable link failing that's causing the battery drain, or do you think everything here is tied to the ignition switch? It's possible we replaced a perfectly good battery 3 weeks ago despite it being a 6 year old Wal Mart special.
3. Is there something in the ignition switch that would keep the starter engaged despite the key not being out thereby draining the battery while the car is totally turned off and parked? This is the part of this dignosis that's baffling me right now.
4. How much,if any, damage is being done to the flex plate ring gear or starter teeth when the starter is forcably engaged while the engine is running? Any way to inspect for damage without pulling the tranny or engine?
5. The other current forum post on battery drain is similar to my situation, but not exactly the same. If there's a short causing excessive current drain other than the ignition switch itself, where would I start looking for it? BTW, when I get the new battery recharged, I'll try the ammeter test described in the other post.
I'm at a friend's house right now so no one is getting frozen outside or anything, but I don't have my Hayne's Manual in front of me to do further checking.
TIA
DMFS
"What's another word for Thesaurus?"- Steven Wright
