Outer door panel? You're most likely looking at replacing the entire door. Remove scuff plate and kick panel, unplug all connectors going to the door. Pull free the wiring's boot at body side, undo 4 bolts on hunge and free the door. Reverse to install. Have fun aligning the door.
Anyway, if it's just a dent, try pulling it first...
Buy my parts
Buy my other stuff
