Transponder Key Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2011, 11:24 AM   #1 (permalink)
akcc's Avatar
View akcc's Photo Gallery
hi, i was just wondering if the toyota corolla 2001 LE have a transponder key? because i have tried searching for it on the internet and have no luck what so ever, my car does have a transponder programmed into the corolla and that being said, is it possible to use a toyota camry key 4C as the corolla key?
are the toyota camry keys between 1997-2001 the same size key as the corolla keys between 1998-2002?
thanks in advance
Toyota Venza 2010 AWD v6
OEM HID + 6000k D4S Bulbs
XM Platinum Series H11 8000k Digital HID
Toyota Camry 1999 XLE v6
XM Platinum Series Bixenon 6000K 55w Digital HID
akcc is offline   Reply With Quote
Old 01-17-2011, 09:38 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
No transponder key for both. I have both in my family. I believe keys for both can be cut from the same type of blanks.
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
Old 01-18-2011, 05:13 PM   #3 (permalink)
akcc's Avatar
well i have a toyota camry 1999 xle and it has a transponder key 4c and i also have a toyota corolla 2001 le, the car has anti-theft / kill switch but the key i have for that car is a non transponder key.. but as i search on the internet the camry 1999 uses the same size key as corolla 2001, so im wondering if the 4c transponder chip can be programmed to work with corolla 2001
Old 01-18-2011, 05:16 PM   #4 (permalink)
Gearhead
Gameroom cash: $196215
You have to match up the FCC ID number to be able to use those keys. If the numbers don't match or not in the same series - doesn't matter if the key "looks" the same, it cannot be programmed for your system.
