These statements are reflecting my own opinion and have nothing to do with repair description described in following article.
The above problem is a result of inferior circuit design and quick pushing of the prototype into the production without necessary testing. The domestic cars demonstrating inferior assembly workmanship, the Japanese cars are suffering due to the component design flaws and materials of budget quality. This can be supported by the high number of electrical system related recalls (2007-08 Honda Fit). From the experience: my friend’s 81 Oldsmobile Delta 88 had only 2 chassis electrical defects (the key reminder buzzer and the fuel level gage). My 79 Supra had mechanical problem with windshield wiper motor and that about it. My 87 Camry required starter relay, instrumental panel circuit board and automatic seat belt repairs. It seems like 99 Corolla shows electrical problems at much earlier age. Thus I will be busy doing car repairs
1999 Toyota Corolla DRL to standard lighting system conversion
While doing accelerator cable adjustment on 99 Corolla I was asked by the owner to investigate two ongoing electrical issues:
• The radiator cooling fans are running all time with ignition on
• The parking lights stays on with switch in off position; turning switch on and off few times solves the problem.
The first problem has been caused by stuck a/c pressure sensor, while the parking lights problem attributed to the DRL module failure. After reading about possible repairs and considering the cost of the new DRL module ($200), I decided to convert the DRL system into the conventional one.
The following article will provide directions how to do it.
The following actions will assure that the lighting system will work correctly without DRL relay in the conventional way as described:
• The switch will turn on the parking, low and high beams (steady on and “flash” functions)
• The parking brake on and high beam on indicators will be working
The procedure requires experience in automotive electrical repair, ability to read electrical schematics and 22 gage wire splicing skills.
Tools and materials required:
Analog multimeter
Screwdriver, Phillips
Screwdriver, Phillips Stubby
Screwdriver flat small (to pry the covers apart)
Socket 10 mm with ratchet driver and
10 mm wrench combo (to remove glove box and negative cable from the battery)
Wire cutters
Wire strippers 16 to 22 gage
Soldering iron, rosin core solder, 1/8 shrink wrap, electrical tape, cigarette lighter and ceramic tile (or equivalent nonflammable heat insulating material)
4 ¼ inch spade crimp-on terminals to make 2 jumpers, 2 feet 16 or 18 gage wire insulation rated to 90-100 degrees C (I used the white one so you can see it easier)
Wire crimping tool
Light and mirror
Parts to be permanently removed from the car: DRL module and DRL SPST relay
Procedure:
1. Disconnect and remove the battery
2. Remove right kick panel and glove box assembly
3. Using stubby Phillips screwdriver, remove the DLR module with bracket
4. Unplug the module and put it aside
5. Cut from the connector and solder together the following wires:
16 and 17 (LGHT GRN and LIGHT GRN-BLK) for tail light relay control
19 and 2 (both RED-WHT) for head light relay control
20 and 3 (WHT- RED and RED-YEL) for low beam/ High beam relay control;
4 and 14 (RED-YEL and RED BLK) for “parking brake on” indicator
21 and 18 (RED-GRN and RED-BLK) for “high beam on” indicator
Strip the insulation 5/16” from the end, twist and solder wires together, then insulate the soldering connections with shrink wrap. (As you can see, I should cut the wires closer to the plastic connector to make soldering and insulating job easier)
6. Remove the DLR SPST relay from the box near the washer reservoir and install the jumper as illustrated into the cavities 1 and 2 /
7. Unbolt fuse/ relay boxes located next to the battery and air cleaner
8. Open the bottom cover of the larger box containing high beam fuses
9. Solder one end of the wire (white one the picture) to the RED-YEL wire; guide wire out of the box and close its bottom cover (see the picture below)
10. Open the bottom cover of the smaller box containing DRL 7.5 a fuse
11. Cut the RED wire coming out of that fuse,
12. Solder the “fuse” end of the RED wire to the WHITE wire that you guided out of the larger box; insulate free end of the RED wire
The above steps (8 to 12) will allow the high beam indicator to function by connecting the part of DRL SPST relay control circuit to the high beam feed wire as shown on the diagram
13. Close the box cover and attach both boxes to the car.
14. Install and connect the battery
15. Check the operation of the parking lights and headlights (high and low beams & flash mode) - no key required
16. Set the multimeter to DC volts; insert the positive probe into the cavity number 4 on the removed DRL relay footprint. Connect negative probe to the good ground. Check for be 12 volts presence when headlight switch is in High Beam or Flash mode; NO voltage must be indicated in parking lights or Low beam position of the switch.
17. If so, remove the meter, install the jumper between cavities number 3 and 4 and verify that the High beam indicator light is on when the switch is in High beam or Flash position
18. Turn ignition on and check the operation of hand brake "on" indicator
19. Install the glove box and kick panel cover
Repair is complete. Thank you for reading
