1ZZ-FE troubleshooting, who's up for it? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2011, 01:25 PM   #1 (permalink)
Big T Dizzle fo Rizzle
BigTDogg (MA)'s Avatar
View BigTDogg (MA)'s Photo Gallery
Exclamation 1ZZ-FE troubleshooting, who's up for it?
New thread, why not, everyone else does it!
LOL... yeah, I could search, and find a bazillion different things to check. But I've already searched, both here and the intarwebs, and I'm still coming up short.
Car:
  • 2001 Corolla LE, 161K miles, standard 1ZZ-FE engine with 4-sp slushbox.
Situation:
  • CEL is on, code is P0420 (Catalyst below efficiency)
Symptoms:
  • Shit gas mileage: 24-25ish MPG combination, sometimes as low as 20mpg. Straight 300 mile highway trip I can eek out 31mpg.
  • Slight pinging (detonation) under hard acceleration
  • Faint exhaust smell when vents are open
What I've changed/performed:
  • Oxygen Sensors (both front and rear with direct plug in Bosch units)
  • Catalytic converter (with direct fit magnaflow unit)
  • Spark plugs (OEM NGK units)
  • Cleaned MAF and K&N filter every oil change
  • Seafoamed vac line and crankcase about 6k miles ago
Mind you, the ONLY code I'm getting is P0420. I'm most concerned with the CEL, because I need to clear it (and have it clear in the ECU) for OBDII inspection testing. Then I'm concerned with the mileage, then the detonation.
I think the exhaust leak is most likely from the flex pipe from the header, as the new cat is welded to the downpipe and the flex pipe section may be over stressed.
My plan right now is to cut out the craptastic Magnaflow unit and get a generic 2" in/out converter from an auto parts place. I am not getting a new Toyota unit, that'll cost more than I paid for the car. If that solves everything, I'll be estatic, however I don't see that happening.
Any help or suggestions are greatly apprecaited. It's got to the point where I'm asking myself why I'm driving the car if I'm getting dick for mileage (which is the primary reason why I bought it).
Thanks
T
My Vehicles:
2001 Toyota Corolla LE - EBC Ultimax Rotors, HPS pads, Goodridge stainless lines, K&N drop in filter, Magnaflow cat and Exhaust, KYB GR-2, Tein H-Techs
1990 Nissan 300ZX Twin Turbo - More mods than Lindsay Lohan has freckles
BigTDogg (MA) is offline   Reply With Quote
Old 01-24-2011, 09:43 PM   #2 (permalink)
Bdub215's Avatar
Gameroom cash: $317265
View Bdub215's Photo Gallery
well... you've got an aftermarket cat so start there, then i'd move to replacing the gaskets/doughnuts for the exhaust, the flex pipe is just that a flexible pipe no wire mesh or anything (unless yours has been changed) so nothing should be wrong there. bump up your octane to premium and go from there. thats what i would do.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
The Following User Says Thank You to Bdub215 For This Useful Post:
BigTDogg (MA) (01-25-2011)
Old 01-25-2011, 02:25 AM   #3 (permalink)
Gameroom cash: $120900
View Milky's Photo Gallery
replace the gaskets like Bdub said. there are 2. one is a donut gasket located at the header to downpipe, the second is located at the downpipe to cat pipe, before the cat. if either has a leak they can cause all the symptoms you describe.
Milky is offline   Reply With Quote
The Following User Says Thank You to Milky For This Useful Post:
Old 01-25-2011, 11:30 AM   #4 (permalink)
Hmmm... the donut gasket may be the culprit. There is no paper gasket with the clamp, that's been removed and it's just welded there now.
I think I may have to add some support to the pipe, maybe on the "chassis brace" which goes across near that OEM clamp. I think the weld is putting too much stress on that donut gasket.
Thanks for the heads up guys, def apprecaited!
Oh, and if you happen to have the part number for that donut gasket (I'll search now as well) and any associated parts I'll need to replace with it that'd be awesome
Old 01-25-2011, 11:43 AM   #5 (permalink)
Bdub215's Avatar
I don't have the part number but I have one sitting in my center console for months now cause I meant to change mine and never did. They're cheap.
Old 01-25-2011, 11:54 AM   #6 (permalink)
I think I found it, does it look like this:
I found a few different manufacturers, Bosal makes one, Ishino makes one (W0133-1637104). If that's the part I'll keep cross-referencing to find the Toyota OEM PN.
Thanks!
My Vehicles:
Old 01-25-2011, 01:40 PM   #7 (permalink)
Gameroom cash: $201383
View teppista881's Photo Gallery
That's the correct part, yes.
I know it would be expensive and a pain in the rear, but you might also try switching your O2 sensors to Denso. There are cheaper roads to try first, but it's always a possibility that the Bosch sensors are giving your ECU bad data and tripping the code.
teppista881 is offline   Reply With Quote
Old 01-25-2011, 01:59 PM   #8 (permalink)
Thanks, I'm definitely going to change the gasket first, then see what happens. I'd be shocked if the O2s are bad. Bosch plugs = bad, but I've had good luck with Bosch sensors in other cars where they weren't OEM.
Old 01-26-2011, 02:54 AM   #9 (permalink)
FYI, my AEM UEGO wideband in my miata uses a bosch sensor. bosch does make really damn good o2 sensors, spark plugs are another thing
Old 01-26-2011, 08:00 AM   #10 (permalink)
How is TN about non-toyota-related threads? I'd love to see some pics and build info on this Miata
My Vehicles:
Old 01-26-2011, 06:23 PM   #11 (permalink)
View adamsautocare's Photo Gallery
Bosch O2 sensors were my problem. I had a p0420. changed my o2 sensors to bosch. Code came back and car was not idling properly. (used a scope and the voltage was way off which has been a problem with our cars and aftermarket O2 sensors I guess). Switched to Denso and no problems since. Not saying that Bosch sensors are no good, but there have been many problems with them and our cars.
adamsautocare is offline   Reply With Quote
Old 01-26-2011, 06:42 PM   #12 (permalink)
View moviestar's Photo Gallery
p0420 = replace the cat and o2 sensors.
rockauto.com for oem o2 sensors.....and take off that shitty magnaflow
also, you shouldn't seafoam your car....its killed a few rolla's I've seen.
moviestar is offline   Reply With Quote
Old 01-26-2011, 09:06 PM   #13 (permalink)
What exactly did it kill?
No point replacing the O2 sensors, they aren't the problem.
Old 01-26-2011, 10:57 PM   #14 (permalink)
clogged one of them beyond repair. Corroded another.
oh wait you don't have a maf do you? jk you have an 01...yeah be careful with it.
Old 01-27-2011, 02:39 AM   #15 (permalink)
well i dont want to annoy a mod or get banned, but here is a link to my miata's pics on my photobucket. i have not done any recent photos since the install, its still quite messy, but come spring ill have it cleaned up and more pics.
http://s910.photobucket.com/albums/a.../Miata%20Pics/
