Originally Posted by 105
Has anyone tried upgrading the stock headlight wiring with relays to increase the light output? I'm just trying to figure out if its worth the trouble.
To see if it is going to be worth the trouble, test the voltage drop in accordance with the instructions
here. (You'll have to scroll down a bit to get to the instructions. Also note the table that shows how voltage changes result in brightness changes, so you know what effect the voltage loss has.)
Remember: Bulbs are rated for life at 14V, and for intensity at 12.8V -- so the closer you can get to 14V (without going over) the closer you'll get to the bulb's rated life. Sure, your bulbs will last much longer if you're not getting sufficient voltage to them, but you'll see much better when you give them higher voltage.
FYI: I've currently got the regular long life Sylvania bulbs installed currently, which are not very bright. I thought about getting the Ultras but I've heard they burn out pretty quick sometimes, like anywhere from 3 months to a year.
Long life bulbs sacrifice intensity for long life; and get even dimmer over time. Long before they've stopped lighting at all, they will have stopped producing enough light.
Skip the long life bulbs, and skip the "Ultras", and get the
Philips X-Treme Power instead. The "Silverstar Ultras" have extremely low lifespan, and the blue glass removes far too much usable light, leaving behind blue light that is difficult for the eye to process.
Another note on the relays: Toyota uses a ground-switched lighting system with a few other complexities. Daniel Stern should be able to provide you a diagram and instructions that accomodate the needs of this lighting system. He also sells quality Bosch relays and ceramic sockets, so you'll know that if you spec out a kit with him you'll not be left in the dark later on.
