Originally Posted by runnyeggsham
I have a bottle of Sea Foam. I was going to put that in after I took out the old gas. It has a little under half a tank. The gas smells like varnish when I open the gas cap, so I am assuming that it's gone bad. Not sure if there are drain plugs underneath the tank.
I suppose if it smells that bad, it's going to be pretty gummy.
The old gas goes to a repair shop that will pay someone to take it away. They will mix it with their waste gasoline.
The trees and our water table appreciate this.
I've looked at some Youtube videos. It might be that my plastic hose is not rigid enough to reach the bottom. They were using rubber hoses. A drill pump seemed the better way to go than my hand pump too.
That may well be true. I'd probably use rubber hose for most of it, then use clear tubing at the near end, and just try to start siphoning by mouth. (I've had to siphon liquids before and have long learned how not to get a mouthful!)
I'd be careful with a drill pump to be sure it's approved for pumping volatile/flammable liquids.
