Im thinking one of the joints went bad but Im not sure. Please help from what you can see!
There is play in the wheel only on the first side if i push at the top, almost as if there is a gap between the rotor and knuckle because if i take off the wheel on that side there is also play between the rotor and knuckle but when the rotor is off there is no movement. When in drive it vibrates back and forth and while driving it causes a rumbling noise, sounding almost out of balance, in the cabin.
I have had the wheel balanced at 3 different stores and swapped wheels thinking it was bent. Everything is torqued down to spec.
The vid will be posted up as soon as it gets done uploading to youtube
