It's SUPER easy to remove. Pull out the trim around the stereo by inserting a flathead screwdriver at the bottom of the trim and prying it up. The whole trim piece (including vents, clock, four way button and defrost button) will pull out easily. There will be four philips head screws at each corner of the head unit. Remove and the unit pulls straight out. Has to be one of the simplest radio install/removals in the world. The fuse will be on the back. You should be able to do this in under 10 minutes.
2000 Silver Corolla LE
Carbon fiber altezzas, reverse indiglo gauges, blue LED interior/swapout, clear corners, xenon headlights/corners, MP3 deck, alarm w/ battery backup & pain generator, mesh grill and repainted exterior.
