Can't find valet switch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2011, 12:30 AM   #1 (permalink)
View dbd1979's Photo Gallery
I have a pre-owned 1998 corolla which had an after market alarm installed before i bought it. Car alarm company is Harada which does not turn up on any results i searched for on the net.
It had stopped working after I had a jump start done about 4-5 years back.
Recently I had to change battery in my car and suddenly the alarm started making intermittent noise and it wont let my car start.
Auto shop guy got the car started after immediately attaching battery terminals so I could drive home and told me to look for a valet switch to disable the alarm.
I have looked under the driver side kick area, glove box etc but cant seem to find this switch. I see the main unit of car alarm installed under drive kick area.
Any help to find valet switch or disable the car alarm will be appreciated.
dbd1979 is offline   Reply With Quote
Old 02-19-2011, 07:18 AM   #2 (permalink)
Mad Microbiologist
RoachRolla's Avatar
View RoachRolla's Photo Gallery
Is the flashing red LED in another location? On my alarm it serves as the valet switch if you push it. But I have Prestige.
RollaRoyce
'02 Corolla
Injen SRI, Magnaflow catback, lip kit, Tein S-Tech, Konig BriteLites, Prestige security, and Mila Kunis in the passenger seat !
26,6xx miles!
http://www.cardomain.com/ride/3842039
RoachRolla is offline   Reply With Quote
Old 02-19-2011, 04:37 PM   #3 (permalink)
View dward3's Photo Gallery
Tell us what color wires you see? Most car alarms can be disabled by unplugging the red, yellow, and black wires from the brain. Take a pic, if possible.
dward3 is offline   Reply With Quote
Old 02-19-2011, 10:06 PM   #4 (permalink)
@RoachRolla, LED is on the dashboard and it does not seem to be pushable.
@dward3, there is a thick black wire coming from the LED and transmittor into the alarm brain. I believe it is a two pin plug that goes into the alarm brain - I removed it but it does not have any effect what so ever.
There is also a big pin that is going in the alarm brain but it is partly consealed so i cannot remove it without removing the dashboard and other plastic parts near the steering. There is a reset type hole in alarm brain which i tried to press - again no effect.
I will try to take a picture and post it.
Old 02-21-2011, 12:13 PM   #5 (permalink)
EdW
View EdW's Photo Gallery
Also, when you say the alarm prevents the car from starting, does it crank but not run, or is it totally dead when you turn the key to start?
EdW is offline   Reply With Quote
Old 02-21-2011, 04:31 PM   #6 (permalink)
Personally, I would take it in to get it checked out by a good installer. Maybe your alarm is just cooked, or maybe its just a blown fuse somewhere. Just take your time. Are you carrying around an 11mm open-end wrench...
