2000 corolla noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2011, 04:49 PM   #1 (permalink)
View casinogoer's Photo Gallery
USA 2000 corolla noise
replaced struts due to metal to metal noise, It didn't fix it, ball joints seem ok, car has 194,000 on the clock what else might it be? what to check?? Noise presents itself on a small bump, up tp large bumps
casinogoer is offline   Reply With Quote
Old 02-20-2011, 06:39 PM   #2 (permalink)
Bennie's Avatar
Gameroom cash: $110951
View Bennie's Photo Gallery
I would imagine you checked out the sway bar end links as well with the work you already did in there but I gotta mention those things. I've replaced a few of them on these cars. I could swear it sounds like a wheel is about to fly off when you have a bad end link.
Also a tip, I always use a big pry bar wedged between the ball joint and control arm to check for ball joint play. Maybe you already have a good method but I've found that to work quite well.
'98 Prizm 4spd 272K bought @ 221K for $300
Oil consumption fixed @ 265K for $247
'99 Prizm 3spd 318K sold to brother 1/2012
Bennie is offline   Reply With Quote
Old 02-21-2011, 04:29 AM   #3 (permalink)
corolla noise
Thank you, will check it
Old 02-21-2011, 10:00 AM   #4 (permalink)
Corolla Owner
leeor_net's Avatar
View leeor_net's Photo Gallery
Also check your wheel's hub/bearing assembly. It's not likely with the metal-to-metal noise but it doesn't hurt to check.
- Leeor
leeor_net is offline   Reply With Quote
Old 02-22-2011, 11:09 PM   #5 (permalink)
View moviestar's Photo Gallery
end links.
moviestar is offline   Reply With Quote
Old 02-27-2011, 03:25 AM   #6 (permalink)
Gameroom cash: $120900
View Milky's Photo Gallery
sound like a metal on metal scraping noise? or more of a banging or popping? if its scraping then i would check the upper strut mounts for excessive wear, if popping or banging, end links like said above.
Milky is offline   Reply With Quote
