Last couple of fill up's in my 98 Corolla, could really smell gas outside the car until the level got below about a half on the gauge. Slid under and took a look at the tank, at first thought it may be the small section of rubber breather hose next to the mail fill line from the fuel neck that connects the small vent tube to the tank. But after looking again on the next fill up's, it seems the top of the tank may be the source, judging from the "stains" so to speak, as they seem to be coming from the top of the tank and down the rear top side.
So I'm wondering if there's a chance the issue could be one of the three round seals on the top of the tank (Fuel pump assy seal, check valve assy seal, or the cutoff valve assy)?
It looks like dropping the tank is a bit involved, and chances are the straps are rusty and going to be shot on removal, so it would be great to be able to determine what's going on before dropping it. Especially if I need a new tank... also hate to buy a new one if it is a seal or hose.
Just had a thought, is there an access plate under the back seat bottom I could use to take a look at the top of the tank?
Thanks in advance for any suggestions.
Here's a link to the tank diagram:
http://www.utoyot8.com/FullImage.asp...-++(9708-++++)
