where can i buy cheap structs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2011, 05:29 PM   #1 (permalink)
View bigpun2323's Photo Gallery
i have a 98 corolla and i need new structs...im wondering if anyone know of any cheap places where i can get them new or used? thanx guys
bigpun2323 is offline   Reply With Quote
Old 02-28-2011, 05:54 PM   #2 (permalink)
pdq
Gameroom cash: $221400
View pdq's Photo Gallery
If you don't care about name-brand, I recommend these StrutTek assemblies. I was able to buy the assembled strut, mount, and coils for less than most places sell the strut by itself:
http://www.primechoiceautoparts.com/...OLLA-1999.aspx
Plus if you have sagging springs in the back, you need new coils anyway.
pdq is online now   Reply With Quote
Old 02-28-2011, 07:06 PM   #3 (permalink)
View Tweek43110's Photo Gallery
^^^Thats pretty cheap ,Id go with them
Otherwise the cheapest youll probly find at a local auto store will be monroes and theyll probly run you about $65 without the new springs, spring compressers, and boot kits. The completes run about $120 and are alot less hassle.
Another thing youll need to consider is sway bar links in the rear will probly have to be replaced (or in my case drilled out) and you will need to bleed your brake lines after its all done since some genius ran the brake lines through the rear struts, so grab some brake fluid.
Tweek43110 is offline   Reply With Quote
Old 03-01-2011, 10:53 AM   #4 (permalink)
View pchalpin's Photo Gallery
Just cut the strut/brake-bracket with a Dremel tool and slide the brake line out through the cut. Install the new struts and zip tie the brake line to the new strut. No bleeding needed.
pchalpin is offline   Reply With Quote
Old 03-01-2011, 12:59 PM   #5 (permalink)
View zoza1982's Photo Gallery
You can go even cheaper with little better quality but little but more work. ( re-using existing spring and mounts)
All 4 shocks only for $149.89 bucks. These are good shocks.
http://cgi.ebay.com/ebaymotors/STAGG...#ht_500wt_1182
zoza1982 is offline   Reply With Quote
Old 03-01-2011, 09:36 PM   #6 (permalink)
Gameroom cash: $816901
View zythr's Photo Gallery
Why looking for cheap? Are you going to be selling this car in the near future?
zythr is offline   Reply With Quote
Old 03-01-2011, 10:36 PM   #7 (permalink)
View militarydave's Photo Gallery
yeah i'd definately not cheap out on the shocks/struts. not only is it a safety road hazard issue, it also regulates the proper wear on the tires. unless you're on some sort of free tire replacement due to irregular wear, I suggest going to a local auto part store (Oreillys, Napa, Autozone, Advance, Pep Boys, Car Quest, etc) and buy the boots, bellows, strut mounts and shocks. must shocks will come with new washers/bushings and locking nuts.
please keep in mind that a 4 wheel alignment is VERY HIGHLY RECOMMENDED after installing all 4 shocks.
trust me. your tires (and your butt [riding comfortably] ) will thank you.
militarydave is offline   Reply With Quote
The Following User Says Thank You to militarydave For This Useful Post:
CamryLooks (07-18-2011)
Old 07-18-2011, 03:19 AM   #8 (permalink)
CamryLooks's Avatar
View CamryLooks's Photo Gallery
I'll be sure to take up your suggestions.
[ 2007 Corolla CE | 2008 Prius | 2002 SC430 | 2006 Scion TC (Red No.: 2) | 2003 Sequoia Limited | 1994 Camry XLE | 1986 Pick-up]
CamryLooks is offline   Reply With Quote
Old 07-18-2011, 06:33 AM   #9 (permalink)
on full afterburner
Gameroom cash: $1346497
You can save quite a bit of money if you shop around on ebay or even hit up our supporting vendors section.
There are a few Toyota dealerships there that give discount pricing to TN members.
