brake caliper q's
hey all, I just changed my 99 corollas front pads/rotors beacuse of vibration with high speed braking even though the pads still had half the life; (my novice brother did the job) and shortly after i noticed slight smoking and smell and some clanging noise from the driver side, and the pickup was stiffer as if the brakes were sticking,
so i called my mechanic friend and he looked at it and saw that the caliper wasnt releasing properly even though everything was structurally intact. Also when we jacked the car up (both sides), in drive, the wheels wouldnt turn. Upon further review, we realized the bottom housing unit for the screw of the caliper wouldnt come out at all even after hammering it, (he said its supposed to go in and out with braking). There was no room for the new thicker pads to function, so he put the old pads back on and it seems to be working well now, with more room.
Now, i dont know how to fix that problem. Do i need a new caliper which is costly or just a new housing nut/screw? Is this a common problem? Thanx guys for any input.
