Originally Posted by Redline322
It is a bit of a tight fit, but you can replace them without removing any other parts and I believe the correct bulbs are H4, not 9003, so you might want to double check that.
For the 1999 - 2000 model years the correct bulb is, in fact, the 9003 dual beam bulbs. 2001 - 2002 model years switched to a dual bulb setup with 9006's as the low beam and 9005's as the high beams.
You should not have to remove anything from the engine compartment to remove the bulbs but it will most definitely be a tight fit, depending on how large your hands are and how skilled you are at maneuvering your hands in tight space. Be sure not to touch the new bulbs with your bare hands - wear gloves if you need to.
As a side note:
SilverStar Ultra's burn out quite fast -- expect to replace them frequently. If the cost of a set of them isn't an issue, by all means get the extra brightness out of them. Otherwise stick with the SilverStar's -- they last about 30% longer than the Ultra's although they're not quite as bright. The real benefit to the SilverStar's, though, isn't their brightness so much as the whiteness of the light they produce. If you don't care how white the lights are and just want a boost to brightness get the Xtra vision bulbs. They'll last about as long as standard halogen's but will produce about 30% more light and they're only a few dollars more than standard halogens.
