Speedometer, RPM and power windows not working! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2011, 06:55 PM   #1 (permalink)
View bettiepug's Photo Gallery
I have a 2002 LE Corolla. Drove 3 hours home today and was working fine. When I started up again and started driving, I noticed the gauges, the speedometer and RPM, were not working as well as the power windows.
The lights, radio, clock, turn signals, door locks, fuel gauge and the horn are all working.
I appreciate it if anyone has any suggestions.
Thank You in advance,
Anne
bettiepug is offline   Reply With Quote
Old 03-12-2011, 07:39 PM   #2 (permalink)
Corolla Owner
leeor_net's Avatar
View leeor_net's Photo Gallery
Seeing as they all seem to have gone out together, and suddenly, it's more than likely a blown fuse. I'm not sure if the windows and instrument panel guages are on the same curcuit but I would assume so if replacing the fuse fixes the problem.
You can find a fuse at any local auto parts store. The big stores may even help you to find and replace the fuse. It'll be a green 30 amp blade fuse. Also look for the red 10 amp instrument cluster fuse (it's not unheard of to have two or more fuses blow at the same time although that usually indicates a wiring problem).
- Leeor
leeor_net is offline   Reply With Quote
Old 03-12-2011, 08:24 PM   #3 (permalink)
Is the fuse box located under the hood? After church, I will take it to AutoZone and see if they can help me with fuses.
Thank you so much for your reply.
Hopefully that is what it is.
Anne
Old 03-13-2011, 07:34 AM   #4 (permalink)
Corolla Owner
leeor_net's Avatar
Both fuses will actually be in Junction Block #1 in the cabin on the driver side. It'll be behind a panel cover under the steering wheel on the left pillar just above the foot rest.
- Leeor
