Replacing 01-02 Brake Lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2011, 05:46 PM   #1 (permalink)
115k miles
01loadedLE's Avatar
Gameroom cash: $123100
View 01loadedLE's Photo Gallery
I just replaced both of mine since one bulb went out and I have seen people ask how to get to them recently so here's how.
-Remove the corner cover panel in the trunk by popping out the two small screw fasteners(unscrew first) and the large fastener using a flat head screwdriver. Then pull the panel out.
-Twist the bulb connector then pull it out of the light housing.
-You now have access to the bulb. Simply pull the bulb out and insert the new one then put everything back.
I did not have to replace the rear window brake light so I did not look at it and I do not remember how it was listed here to change that so if anyone remembers how to do that then please include the info.
I'd rather be flying.
Pics & info on my 01 LE
01loadedLE is offline   Reply With Quote
