How to replace rear vent window? (small triangle one) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2011, 03:54 PM   #1 (permalink)
View azncapcom's Photo Gallery
Long story short, car was parked at a mall and when i came back to the car, the small rear triangle glass was smashed... nothing was stolen though, so i don't know why they smashed it.
Anyways, how would one go about installing a new one themselves?
thanks
azncapcom is offline   Reply With Quote
Old 03-18-2011, 04:06 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Might want to call a glass shop and see how much they charge for that - might be cheaper than you think (have to factor in time, getting the part, warranty, etc.). But DIY is not too bad, lot easier than doing the front or rear windshields.
I've seen people replace that little piece with the door window still in place and with it removed. The factory service manual has you remove the main window. If you want to try and keep the window in there - roll the rear window down first.
First you'll have to remove the division bar that runs between the smaller rear window from the main rear window. Have to peel off the interior panel to get at one bolt. The other are on the ends of the division bar. I believe those are Torx head, but can't remember off the top of my head.
Once that is out, you'll see the weatherstripping to pull off / peel back to get at that vent window. Depending on where you get the replacement window - could come as just the glass or as an assembly with the weatherstripping already attached.
Old 03-18-2011, 04:46 PM   #3 (permalink)
I've found a thread for the DIY on the 7th gen, would it be the same for the 8th gen? Also how would i go about it without removing the main window?
