Concerns on axles able to move in and out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2011, 02:32 PM   #1 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
My car has been vibrating for months now and i have checked all tie rods and wheel bearings and nothing seemed to be wrong with that. When it vibrate i did have it balanced again and it wasn't that.
It would now vibrate at certain times and disappear and then reappear.
I went in and check on my axles...you know how where the axle plugs into the transmission...well before that the axles plug into this big round steel thingy and that thing will be plug into the tranny. Well however, both sides are able to move left and right from the tranny hole when i wiggle it or so. You can kinda pull it out like at least 1/4 of an inch or so. Is it suppose to be like that?i thought it was suppose to be stiff in and that you can't pull it out or in.
I ain't no real mechanic brainer so i am just explaining my best.
ilovecorollale is offline   Reply With Quote
Old 03-22-2011, 06:11 AM   #2 (permalink)
Bennie's Avatar
Gameroom cash: $110951
View Bennie's Photo Gallery
The yoke that installs in the transaxle should not have any play, neither should the other end that installs in the hub. The "big round steel thingy" is the CV joint. There are obviously 2 of them on each CV shaft. They both need to move in and out (changing the length of the CV shaft) to allow for suspension movement. There shouldn't be any other play anywhere on the CV shafts.
'98 Prizm 4spd 272K bought @ 221K for $300
Oil consumption fixed @ 265K for $247
'99 Prizm 3spd 318K sold to brother 1/2012
Bennie is offline   Reply With Quote
Old 03-24-2011, 09:40 PM   #3 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
Does it vibrate under acceleration then go away when you let off the gas?
1990 Camry Wagon, 270k, Gray, Retired
1993 Corolla Wagon, 231k, White, w/White Tenzo R's
1994 Lexus ES300, 141k, Pearl White, IS300 Rims
1973 Chevy C20, 76k, Metallic Green, 454 BigBlock
1994 Lexus SC300 1jz 61k Black
zppeacock is offline   Reply With Quote
Old 03-25-2011, 10:30 AM   #4 (permalink)
Yeah it does vibrate slowly on acceleration almost like on a bumpy ride. there is still vibration when i let off the gas on a slow pace and at a fast pace.The car (at a slow speed) would feel as if it goes up and down on a flat road making kinda bumpy a little.
